new here
Re: new here
Postby Joakwin » Wed Feb 11, 2015 6:34 pm
im not sure where that clip goes
but it should be number 29 in the link that hooks the cable up to the carb
http://www.minispares.com/catalogues/cl ... spx?1~6~58
or number 10 in this link
http://www.minispares.com/catalogues/cl ... x?2~12~118
I think the part I need is the same one that is used for the heater valve cable on the engine, and with the weather we have right now, don't really need a heater
Joakwin
Re: new here
Postby JPMINITUCSON » Thu Feb 12, 2015 12:58 am
Ah! That's known as the "Trunion" on this side of the pond.
A little part with a big job!
http://www.7ent.com/products/cable-trun ... e0034.html
Jon
'81 Aussie Moke Californian
'61 Morris Mini-Minor
'71 Cooper 'S' MKIII
'76 Mini 1000
'13 MINI Cooper
JPMINITUCSON
Re: new here
Postby Joakwin » Thu Feb 12, 2015 2:59 am
Oh yeah that's the one
I think the one from the heater cable is the same
I will post more pictures this weekend
I found a oil filter for the 998 at Walmart for $3.21
Of all the places, lol
Joakwin
Re: new here
Postby JPMINITUCSON » Thu Feb 12, 2015 3:58 am
Lots if spin on filters fit the Mini:
Oil filters
AC-DELCO 93156323
AC-DELCO PF53
AMSOIL SDF-57
BALDWIN B288
BECK/ARNLEY 041-8988
BOSCH 3330
BOSCH 72150 NOW 3421
CASITE CF966
COOPERS GFE1
COOPERS Z25/2
DELPHI FX 0004
FRAM PH2870A
FRAM PH3600
FRAM PH3614
FRAM PH966B
HASTINGS LF155
K&N HP-2004
K&N HP1002
LUCAS F5578
MANN 056 115 561G
MOBIL M1-102
MOPAR 4105409
NAPA 1374
PIPERCROSS OF106
PIPERCROSS OF106-RBT
PUROLATOR L10028
PUROLATOR L10241
STP S3614
UNIPART GFE148
UNIPART GFE166
UNIPART GFE21
WALMART ST3614
WIX 51374
Valvoline VO25
Jon
'76 Mini 1000
'13 MINI Cooper
JPMINITUCSON
Re: new here
Postby Joakwin » Thu Feb 12, 2015 2:29 pm
I went with this filter
PUROLATOR L10241
Joakwin
Re: new here
Postby Joakwin » Mon Feb 16, 2015 12:40 am
Drove the lhd mini to Yuma and staying the night
Turns out the headlights didn't work because the connectors where it T's off at the front panel
Was bad, ez fix
My turn signals and 4 ways don't work
I know the flasher for the turn signal is bad
And the flasher for the haz isn't hooked up
But the turn signal will be ez to make work
And the idle was at like 1500rpm, lowered it down to
1k
And the car drove nice,
In the mountains the car didn't like it
But never got hot, I did like 80km
And then flat highway rolled at 110km
And if I had to pass the car pulled nice to
135km
It's a Germany spec car, I'm not really sure how fast I was going
But I think 100km is about 60mph
Joakwin
Re: new here
Postby Joakwin » Tue Feb 17, 2015 1:23 am
Ended up using 12 gallons of gas to drive from San diego to San luis Az to tucson AZ
Joakwin
Re: new here
Postby JPMINITUCSON » Tue Feb 17, 2015 1:48 am
Great, about 35 mpg.
Do you have twin tanks?
Jon
'76 Mini 1000
'13 MINI Cooper
JPMINITUCSON
Re: new here
Postby Joakwin » Tue Feb 17, 2015 2:10 am
Single tank
Gas stop is a nice few min break
Next to my brothers gasser
Joakwin
Re: new here
Postby Joakwin » Tue Feb 17, 2015 8:58 pm
I think the clutch went out on the car, its not wanting to disengage the clutch anymore
well, I guess the good thing was that it didn't brake down on the road
bad part is, I need to buy a clutch kit and take the few hours to swap it out
its a verto clutch and the pedal is going down to the floor and its not leaking oil from the slave or master
looking online
mini mania wants $240 plus shipping
7 ent wants $209 plus shipping
gbcar parts $190 plus shipping
dsn classic, 100GBP and flat rate shipping if it will fit in a USPS flat rate box
Joakwin
Re: new here
Postby JPMINITUCSON » Tue Feb 17, 2015 9:55 pm
If the slave is not moving it is probably the master. Maybe just new seals and a light hone would get you moving.
Jon
'76 Mini 1000
'13 MINI Cooper
JPMINITUCSON
Re: new here
Postby Joakwin » Wed Feb 18, 2015 2:49 pm
the slave moves about a inch
I adjusted the plunger nuts and now the clutch has travel
the radiator is leaking at the lower cap
Joakwin
Re: new here
Postby Joakwin » Fri Feb 20, 2015 2:59 pm
i started to JB weld the radiator but its pretty bad, the lower cap and the lower outlet, so I ended up ordering an alloy radiator for the car, and I will have it next week sometime
Joakwin
Re: new here
Postby Joakwin » Wed Feb 25, 2015 11:40 pm
Alloy radiator was just dropped off by team ups
2-core radiator
Joakwin
Re: new here
Postby Joakwin » Mon Mar 02, 2015 2:42 am
Got the radiator installed this afternoon and messed around with the clutch,
Removed the old oil from the clutch master
And put some new stuff in and
Bleed it out to what seemed like a million times
While keeping the level in the master good
And now the clutch pedal feels a ton bit harder to push
And the slave is movng out about a inch to 1.25 inch
And the box is shifting smooth like it should
We'll see if this thing holds pressure for my drive to work tomorrow
Joakwin
PreviousNext
Users browsing this forum: No registered users and 38 guests
