new here
Re: new here
Postby Joakwin » Sun Oct 25, 2015 12:35 am
I still haven't took the car to the mvd,
The coils on the coilover are starting to set and now the coil is rubbing on the inner side wall tires up front
So I need to space it or re make the mounts
I probably won't take the car to mvd till next yr
I'm going to have surgery on my hips for torn labrums
I upgraded the stereo in the garage,
ready to work on my mini's and rock out At the same time
2500watts for the subs and 1400watts for the tops
The subs are 18's and the tops are 18's with horns
Joakwin
Re: new here
Postby JPMINITUCSON » Wed Nov 11, 2015 10:48 pm
Joaquinn, I was unpacking back issues of Mini Magazine and came across a 3 page story on your Mini build in the April 2013 issue. COOL! :D
Jon
'81 Aussie Moke Californian
'61 Morris Mini-Minor
'71 Cooper 'S' MKIII
'76 Mini 1000
'13 MINI Cooper
JPMINITUCSON
Re: new here
Postby Joakwin » Mon Dec 14, 2015 7:57 pm
Started some glass work on the front clip
I'm making the wheel wells lower and opening them a bit
So the front clip will clear the tires a little bit better when turning the wheels left or right
1st I started out with a card board cut off and the. Transferred it to some sheet metal
Joakwin
Re: new here
Postby Joakwin » Mon Dec 14, 2015 8:01 pm
Next I screwed and glued the sheet metal to the inside of the front clip
Ones the glue dried I welded up the lip I put on the sheet metal
After that I started to fiberglass
So far I have 3 layers
And then the fun part came, body work
Aka sanding like crazy
It's starting to take shape and I'm pretty happy with the out come
Joakwin
Re: new here
Postby Joakwin » Mon Dec 14, 2015 11:55 pm
Joakwin
Re: new here
Postby Joakwin » Sat Jan 16, 2016 8:51 pm
body work on the right side
4 coats of paint and some wet sanding and starting to wax
started to paint the trim parts on the front clip
the front bumper has been repainted
one of the headlight rings is repainted
and one headlight has been cleaned
after lunch the front lower valance will be painted and the bumper mounted
Joakwin
Re: new here
Postby Joakwin » Sun Jan 17, 2016 12:56 am
I had a small space heater close to the left side,
right side came out good but the left side im not happy with
im going to sand down the left side and re-do it
Edit:
I have it sanded down but I don't think I will have time
To paint it again before I leave to San Diego
I have to get more plastic for over spray to cover the car
I'm having hip surgery next Thursday in San Diego, so
I'll end up waiting to march to repaint, and the weather
Should be alittle better by then
When I come back from San Diego, my dad and I are going to tow
Back my next project, used to belong to my grandpa,
A 1937 Chevy truck, powered by a 2002 5.3/4L60e out of a Yukon
It still needs a ton of work but it's the fun of working on vehicles that I like
Joakwin
Re: new here
Postby 66Cooper » Sun Jan 24, 2016 11:59 pm
Wishing you the best and a quick recovery from your surgery.
Re: new here
Postby Joakwin » Mon Feb 22, 2016 4:00 am
Getting ready to go in for my right hip job
My 1937 Chevy truck on the trailer outside of Mr. G's in Yuma AZ
Joakwin
Re: new here
Postby Joakwin » Mon Feb 22, 2016 4:11 am
I picked this 2000 s10 blazer front clip up for free in phx a few days ago
I'm planning a 2x3 3/16 frame from the front suspension to the rear of the cab and then box in the rear part of the truck frame
I plan on doing a tri 2 link in the rear with super joints and a really long pan hard bar
Joakwin
Re: new here
Postby Joakwin » Mon Feb 22, 2016 4:15 am
I plan on using some oem z06 calipers and rotors
I picked them up from the Chevy dealer
Joakwin
Re: new here
Postby Joakwin » Mon Mar 21, 2016 2:59 am
Finally got around to reprinting my left fender
Joakwin
Re: new here
Postby Joakwin » Mon Mar 21, 2016 3:03 am
I ordered up some vw bug brake remote reservoirs because the wilwood ones suck
They leak all the damn time
Besides that, I've been working on the 37 like crazy
It has a few rust spots on the shell
Joakwin
Re: new here
Postby JPMINITUCSON » Mon Mar 21, 2016 3:06 am
Time to take a break and come up to Catalina. I need a good panel beater to give me some ideas on getting the Moke squared away. Oh, and great work on the Mini. What color is that? hard to tell from the lighting.
Jon
'76 Mini 1000
'13 MINI Cooper
JPMINITUCSON
Re: new here
Postby Joakwin » Mon Mar 21, 2016 3:50 pm
It's a cream or a almond white
It's pretty close to the off white color that is used on the new mini's
But it's a little different and that's what I was going for
I had this thing in od green back in 2012
And deployed and when I got back I saw a bunch of classic mini's
In the UK that were the same color, so I painted it this color in 2013
I just wanted my car to look different from every other classic mini
Joakwin
PreviousNext
Users browsing this forum: No registered users and 32 guests
