Turbo Kits for R53 Coopers
Anybody know if there is such an animal as a supercharger or turbo kit for R53 Coopers (non-S)?
Arizonas MiNi Motoring Club!
http://dynamicminicollective.org/forum/
http://dynamicminicollective.org/forum/viewtopic.php?f=1&t=5496
MCS08 wrote:Anybody know if there is such an animal as a supercharger or turbo kit for R53 Coopers (non-S)?
deemotored wrote:Never dyno'd. Too scared something will break!
GOTCURVES wrote:While all of this sounds like alot of costs, it pales in comparison to the ECU which by itself would cost well over 2K then you need to get maps written and programed which could cost as much as another 2k so bare minimum the ECU alone would run over $4,000.
GOTCURVES wrote:How is it you are able to effictively map a turbo with the memory capacity of the R50? I was under the impression that the R50 ecu lacks sufficient memory to accurately map a turbo engine with it (at least that's what Jan at RMW said to me). The boost curves alone are completely different so an S ecu map would sill need boost control via wastegate (oooooooo the lines of code that must be written), a larger fuel pump and rail would need to accompany the larger injectors (but thats if you want more than S power and maybe more than JCW power).
Some questions.
What are you doing for intercoller placement? what size?
Are you relocating the steering pump and coolant reseviors?
Do you relocate the battery?
Have you resized the connecting rods or reshaped the pistons?
What kind of boost levels are you ataining with 91 octane?
Will you map for higher octanes if so at what level octane /boost?
Did you do any crankshaft work?
Resize displacement?
Did you run into any issues with the 5 speed to 6 speed shifting linkage?
Mike it will be interesting to see what kind of numbers these conversions do, please keep us informed.
