Convertible Owners - Weather Strip Inquiry
This is for the convertible owners. Are any of you experiencing the same problems we are?
2008 model purchased new in July 2008 and has 19,000 miles on it. The car is garaged at home.
Between the top fabric and the body is a chrome molding/trim. On top of the chrome molding is a rubber strip.
Here are the three problems/defects we've noticed:
1. On the sides of the vehicle there is a gap in the moulding. Which appears normal, but the rubber strip is starting to peel to the rear of the car and break off. So far, about 1/2 inch has broken away on both sides and continues its rearward tear.
2. Along of the back of the car (between the tail lamps and the third brake light) there are two problems:
2a. We have a three inch horizontal tear in the rubber where it meets the chrome trim. The top of the rubber is ok, just a definte horizontal tear at the trim connecting point.
2b. At several spots there are perfectly verticle tears the full verticle height of the rubber strip.
I don't notice them in low light conditions, but once out in direct sunlight, the damage is very apparant. We only use the convertible top vary sparingly. Basically, only 1% of all driving is with the top down or moonroof open.
I only handwash my vehicles, so its not taking a beating from mechanical car washes.
Has anyone experienced this?
Would you consider it a warranty item or normal wear and tear for these cars??? Do you think MNS would replace it without a lot of hassle under warranty?
