Photo radar defender
Dedicated to unrelated topics...
Postby azminiman » Mon Jun 29, 2009 4:36 am
This has to be one of the coolest defenders of the Photoradar I have seen. It is a very thin peice of highly polished steel (or something ) about the thickness of a credit card. In the shape of a sharks tail.. ( just for looks i gather.. a square peice would be more goofy looking ) when you look at it streight on it cant be seen.. looks like a very thin black line down the center.. but from a side view... you cant make out the full plate. I was close up for the picture.. but if you step away, especially from the distance of the camera from the side, you cant see the left side of the plate at all....GENIOUS I SAY !!! I highlighted the second shot in red to make it more visable...
[b]Former DMC founding member, 1st new MINI owner in AZ, 10 time AMVIV, 3 time MITM, 3 time MTTS, 2 time MINI United England-France. Visitor to 80 MINI dealers in US, 10 Canadian, and 6 European countries.[/b]
azminiman
Postby MCS08 » Mon Jun 29, 2009 7:17 am
When did you pick up the Boxter Mark? :lol:
"If you love someone, let them go. If they come back, set them on fire." -George Carlin
MCS08
Postby Louie B. » Mon Jun 29, 2009 12:59 pm
He needs to mount it to a slimmer frame, his is blocking half of the word Arizona.... naughty naughty! :roll:
Postby MINICDN » Mon Jun 29, 2009 2:21 pm
Here you go Mark:
http://www.thephotofin.com/home.html
All you wanted to know about the Photofin! :D
07 MCS AB/AB Hypersport Redwood Lounge Leather, JCW Stage 1, NM Springs, Sway Bar, Strut Brace
MINICDN
Postby bonehead04 » Tue Jun 30, 2009 12:35 am
What's the legality of that thing? If you have MCSO riding on your butt and they see it, can they do anything?
'08 Astro Black MCS, 6-spd
bonehead04
Postby OPC » Tue Jun 30, 2009 12:56 am
Is it legal? You can decide for yourself if you'd like to be our test case:
28-2354. License plates
A. A person shall display the license plate or plates as follows:
1. For a motor vehicle, motorcycle, trailer or semitrailer, on the rear.
2. For a vehicle for which two license plates are issued, the vehicle owner shall display either of the following:
(a) One plate on the rear.
(b) One plate on the front and one plate on the rear.
B. A person shall display all license plates as required by subsection A until their lawful use expires or is canceled or revoked. A person shall maintain each license plate so it is clearly legible and so that the name of this state at the top of the license plate is not obscured. A person shall securely fasten each license plate to the vehicle as follows:
1. To prevent the plate from swinging.
2. At a height of at least twelve inches from the ground to the bottom of the plate.
3. In a position to be clearly visible.
Jos
OPC
Postby bonehead04 » Tue Jun 30, 2009 1:01 am
OPC wrote:Is it legal? You can decide for yourself if you'd like to be our test case:
Ha. No thanks, Jose. These parts are where it's very open for interpretation. I, however, don't have the time or patience to argue with a court. Besides, that thing just looks silly. :roll:
bonehead04
Postby OPC » Tue Jun 30, 2009 4:28 am
:lol:
Jos
OPC
Return to Miscellaneous
Users browsing this forum: No registered users and 54 guests
